warren540 »
https://forums.nicoclub.com/warren540-u39654.html
Mon Apr 17, 2006 5:04 am
Well it's the third day on the install. I been taking lots of pictures. I will post a full write up on the whole swap very soon.
Anyhow, I've run into some problems..the car i used was a auto 1991 s13. i pulled the transmission and cut the harness knowing i won't be using any of those wires. My question is, will it affect affect it on start up? Do I have to rewire anything because the car thinks it's in drive and won't allow it to crank? Because it won't start. It cranks if I manually put a screwdriver on the starter.
Next question. Will the car start without the MAF?
Where is the boost selenoid located?
How do I plug the fuel Wires? I don't remember if the fuel filter goes on the top line or bottom.
and last but least, Where is this wire located. I don't have the KA harness anymore. (From the KA ECU plug, connect Red wire (101 ECCS Relay))
