DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Fri Nov 07, 2003 2:45 pm
I have a similar model, different brand. It works really well, except that the pressure valve on mine is backward from what the instructions say AND from what is standard with every air compressor I've ever used. I almost broke it trying to figure out why I wasn't getting any pressure. They all work the same way from what I can tell, so it seems that the only difference might be in the brand of cleaning solution you use.
