3inch catback exhaust on stock (ka24de)
sxcoupe
Car: '95 bmw M3 coupe
i have asked this ? on other threads. has anyone installed 3inch exhaust to stock catalytic 2.25 i have got mixed ansers on this. two guys said they bolted right on but did not give details others have said they have had problems.can it be done
Silvia007
Car: 93 Nissan 240SX SE Fastback
If the exhuast is made for your car. It will fit just fine. My buddy with a 3 inch Rocket exhuast made by greddy or hks, forgot which, installed just fine on stock cat. Mines a 2.5 from BRM and it fits fine... even when I put in a high flow it fit just fine.
SeanC
Car: 1993 240sx SE
i have a 3" cat-back custom done by me going to a 3" magnaflow very deep and kinda loud. but once i put the turbo kit on it should quiet it up a little.
DeXteR
Car: '14 Nissan Titan Pro4X
'05 Nissan Xterra OR
'92 Nissan 300ZX Slicktop
'94 Nissan Sentra RS Rally Car
sxcoupe wrote:i have asked this ? on other threads. has anyone installed 3inch exhaust to stock catalytic 2.25 i have got mixed ansers on this. two guys said they bolted right on but did not give details others have said they have had problems.can it be done
so here's the ? you posted in my thread...
the answer is that the flanges should be the same size on your cat and your cat back. the diameter for the pipe is the only thing that is different (if at all, as some cat-backs have a smaller inlet just for matching up with the cat). so you can have a 2" cat outlet butted up to a 3" pipe inlet for the rest of the system. sure there'll be some turbulence at the connection, but it won't make a big difference.
byonata
Car: '89 KA24E
My bro had his 1990 240sx Fastback equiped with HKS Hi-Power 80mm pipe catback.
If you're going for turbo, 3". N/A then either. I suggest you go with the 80mm pipe catback. More airflow, and SR ready
TAMHA101
Car: 1992 NISSAN 240SX HATCH BACK
I have an HKS Hi-Power 80mm pipe catback on my hatch without any problems. With the stock cat still on.
TanManS14
Car: 1995 240sx
What's your set up with the 80 mm HKS, do you have an SR, and does it sound deep?
sxcoupe
thanks for the feadback that helps
