3an oil line
95 kat
Car: 95 240sx
ok i have read that if you run -3an oil inlet line you dont need a restrictor. I am running a t3/t04e and wasnt sure what i needed. Just wanted some input so i dont blow it up . Thanks!
Jookmasta
-3 AN is the right size line if u dont want to run a restrictor................
KATwo40
Car: 1993 240sx KA-T
I ran a -3an and STILL needed a restrictor!
-3an = less volume, more psi.
Of course, my turbo is a small Mitsubishi turbo, so it's oil inlet may be different from that of a more common KA suited turbo.
Structure240sx
i personally would always run a restrictor unless your turbo has a built in restrictor. certain garret GT series have built in restrictors
Jookmasta
well i can say that for a str8 T3 60 trim, -3 AN is the right size
240SicknessX
Car: 96 240 SE
the fitting that mated the -3an feed line to my garrett was 1\8th. no issues.
