38mm wastegate
EVILS14
Car: 1995 NISSAN 240SX SE RB25DET
with a 1 bar spring how much boost can you get out of one
Modified by EVILS14 at 10:18 PM 2/7/2010
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
14.7 off w/g and more w a mbc or ebc
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
It depends on flow more than boost. Therefore, it also brings in your piping configuration into the picture. Maybe if you summarized what your plans are as far as boost, manifold, and piping arrangement we could give you a better answer.
Without knowing anything else, I'd take a WAG at 30 psi (obviously assuming that you'll run a boost controller)
240z4u
Car: '95 Nissan 240SX
The more boost you run, the smaller W/G you can use essentially.
Darius is dead on though, and actual placement is a big deal too.
Evan
EVILS14
gt3076r, apexi avc-r and hopefully a 6boost manifold. not sure about boost but looking to get 480 to 500hp and i was just wondering if a 38mm would be good enough or should i go bigger
240z4u
Ill be honest, I am not sure. I don't really know what the compressor maps look like. If you run a well designed setup Ill bet the 38mm will be okay. You can always weld on a 42mm flange then use an adapter to a 38mm just in case you want to go up in size.
jacksonbrown
Car: 1989 240sx/RB25DET , 1989 240sx/355 Chevy
I have a Synapse 40mm and had a previous one stick wide open at wide open throttle and boost dropped to 4lbs while holding. This was with holset hx35 with 18cm exhaust side. Correct the more boost you run the less gate you need, but at the time this happened I was trying to run 10lbs which is alot to bleed and worked fine.
