370z wheels 19x9.5 and 10.5
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
Eavamnba
Curious if the 370z wheels as described above would fit an 06 g35 with out issue any help is appreciated.
biggie
Would have to find out the offsets to be sure. My guess is they will fit, but won't look right due to higher offsets.
370Z/28
Car: 370Z & Z28 *SOLD*
'13 Lexus IS250C F-Sport
The back ones have a very deep offset...look how much the fender sticks out. I would say even if it fit, it wouldn't look good at all.
biggie
Ok, took the time to look.
Found this for the Nismo 370z wheels:
19X9.5 +40 front
19X10.5 +23 rear
VS the Rays 19" G35 wheels (19x8 +33/19x8.5 +30)
Front:
Wheel Inboard increase (inches): 1.025
Wheel Outboard increase (inches): .474
Rear:
Wheel Inboard increase (inches): .724
Wheel Outboard increase (inches): 1.275
So would worry about room for shock/spring or coilover in the front and the fender in the rear. Will depend on tires as well.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Run a spacer up front, at least a 20mm and a 10mm spacer in the rear and those will fit the g35 coupe like a glove...
Commonly used after-market offsets:
Very Aggressive:
Front width: 9.5" +19mm offset
Rear with: 10.5" +17mm offset
Aggressive:
Front width: 8.5" +20-22mm offset
Rear width:9.5" +22 mm offset
Just keep in mind this aggressive setup won't fit so well if the car is not lowered.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
