370cc injectors
nimtZ
Car: 300zxt
hey i ahve a ka and 370cc with safc and stock ecu and i was wondering if anyone knoiws how much to correct for idle?
Jookmasta
i personally used -25% across the board for about a week. i just moved it to -26% across the board. car doesnt backfire as much but i did notice a drop in mpg with -25%. So just adjust this in the high and low throttle menu in the safc.
KATwo40
Car: 1993 240sx KA-T
Mathematically speaking, the stock injectors are 270cc/min. In calculation, to imitate the stock air flow reading, you'll need to reduce the injector pulse by 37% (270 is 37% of 370). However, the ECU is tuned to run N/A, which would be around 14.7:1 ratio. Since you're turboing, you'll want to run more like 11.9-12.2:1, resulting in somewhere around 25-28% reduction in pulse.
The best thing you can do is hit it at aroud 25-28%, then go straight to the dyno (with wideband O2 testing) and tune it.
SloMoe
Car: Fast Cars, Music, Girls
KATwo40 wrote:However, the ECU is tuned to run N/A, which would be around 14.7:1 ratio. Since you're turboing, you'll want to run more like 11.9-12.2:1, resulting in somewhere around 25-28% reduction in pulse.
For idle speeds you can run it leaner, its under load and WOT where you really want to richen up the mixture. 11.9-12.2 is kind of rich for an idle mixture.
KATwo40
Well, yeah. LOL sorry, forgot to add that little tidbit.
Jookmasta
so ur saying that i could put the safc to -30 or 35% since i dont have my turbo on yet and still be fine since i am still NA? if it helps out on the mpg and is still safe, im game to try. i always read that b/w -25 and 27% was where it needed to stay...........
KATwo40
That's correct...for a turbo application, because it needs to be richer than N/A. I'd put it at 30%, then go to the dyno with wideband testing and pay for a half our or tune time. See what your AFR's are and tune accordingly.
Actually, lemme change that...
I'd wait to put the injectors or the SAFC in until I got my turbo stuffs. Then, I'd put it all together, put the SAFC at 28%, then drive carefully to the dyno and spend an hour on test/tune.
Jookmasta
well im NA and i currently run 26% so i guess i should b running it more lean since i am NA? what should it be set at then?
