JNM240 wrote:I dont have the diagram for the SAFC but i do have the diagram for the 90 ECU pinout. If you could tell me what the wires need to go to (like which is MAF, which is injector, ect), i could tell you where on the ECU harness they belong.
And as for your injectors, i believe the only way to get them to work properly is to remap your ECU to handle them. BTW, where did u get them? What brand? How much? Do you happen to know the stock injector cc's?
Hmmm... Is there a knock sensor wire?
I got my hands on the ECU diagram for my car, I think it's good, found from searching on this forum.
However, I've tried reading the darn thing, and it's confusing. Some of the pieces, like air-flow meter and throttle, have multiple wires going into the ECU and I don't know which wire to tap into. Well, I eventually found most of them with the SAFC diagram, but even then took some trial and error.
Anyway you can send me your diagram so I can see if it looks the same as the one I have (I don't think I have the factory one, but not sure).
