MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Fri Jan 07, 2005 12:28 pm
Just make sure all the injectors have the pintle caps on them, and order a new upper/lower fuel injector O-ring set from Nissan (your dealer may have them in stock). They drop right in the KA fuel rail so just tell the guy that you have KA 270cc fuel injectors--both SR and KAs use identical o-rings.
If you want, it's always a good idea to have them flow-tested/serviced by a place like RC-Engineering, but it'll probably cost you just as much as the fuel injectors themselves, but it adds to the peace-of-mind factor.
So the short answer: they'll drop right in, just make sure you get new o-rings for them.
But no, you cannot go ahead and install them unless you have an S-AFC or an ECU (JWT) tuned to handle them.
Hope that helped, and welcome to the KA-T side of the forums
