370cc Injectors good for more than 250whp??? How is this possible....
turblu
While searching on srforums.com I ran into this guys spec sheet along with many more very similar to it:
From SRForums.com"my old set up--ported T3370"s 255 f/ppro-tech log manifoldjwt ecu programed for 9.5 comp,370's,4 bar ,cobra maf3" turbo back w/catfront mountgreddy type s bovtial 35mm w/g
18psi spiked 20 for a secmax power was 304.2 and max torque 284.7 this was done on a dynojet
my new set up has never made it to the dynotomei 260'st3t04e .63 exh 50 compsame protech manifold and tial waste gate50 lb msdreprogramed jwt 50lbers at 4 bar,cobra maf and 9.5 comp. 3" turbo back greddy type s bovaromotive fpr
looking to hit mid 300's"
- How are these guys hitting 300+whp with 370cc injectors? Is the bluebird engine that much different?
S13FASTBACKSR
Car: '92 Fastback SR powered
with the right mods then yes they are capable of it..they max out at what..12-14lbs of boost?
corey240
Car: 1993 Nissan 240SX Base Drift Machine
its not possible period. if it was everybody on here would just be using them instead of 550s or 600s for 300 hp. hes bs ing period.
S13FASTBACKSR
Just re-read the original post..18-20 psi on 370's is definately a HUGE load of BS. It is possible to make a little over 250whp on 370's but not 300 IMO
