WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Wed Jan 30, 2013 1:11 pm
Not so. But it depends greatly on what you consider a "decent amount of boost". It also depends on the tune and how much timing is retarded for each lb of boost. Then you can consider things like water/alcohol injection. A decent alcohol injection kit only runs about $350. Run some basic windshield washer fluid, $3.00 for something that is for -30F, and you can run as much boost as you want. I say use the -30F fluid because it contains the most methanol sold in stores. About 35%. If you add a bottle of Heet it will ramp up the mix to 50/50 methanol/water. That's about as much as you'll want to run because most pumps don't like that much methanol.
The key is eliminating detonation, aka knock. Without alcohol injection you could run 6-8psi with the proper tune without any troubles. That will net you about 80whp give or take a bit. 80 extra ponies makes your vehicle an entirely different animal. I always recommend running some sort of water or alcohol injection just for safeties sake, especially on a motor that has a high compression. I think the VG30DE has 10.5:1 static compression, not sure about the VG30E.
Point is, it can be done pretty easily and for not to much $$. I would boost a J30 in a second if I owned one.
