BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Sat Apr 04, 2009 8:56 pm
The likely cause of your premature engine failure was due to a defect in the engine, either poorly cast rods, a blocked oil port in one bearing, or something more trivial. Not taking care of the engine properly (which, imho, you are guilty of), was probably not the cause of this failure. I recently lectured my co-worker for not changing his oil in 10,000 miles. He owns a 2003 Saturn Vue with over 100,000 miles on it, and the engine was beginning to tighten up. After changing the oil, the difference was night and day. There is no excuse for not changing the oil regularly, at least every 4500 miles. An engine can cost several thousand; an oil change can cost as little as $12. You need to know that the oil passages on some of these newer engines are TINY; it can take very little to clog them (and oil filters will automatically bypass if THEY are clogged, allowing debris and sludge to circulate through the engine).
