35mph + vibration
sparrow
:crazy:
2003 4wd se pathfinder. Frame/body vibration 35mph + . Worse under load and worse in 4wd. Wheel bearings tighted and repacked. Any help appreciated. Thanks.
rgk
Car: 02 Pathfinder LE 3.5 auto 4x4
First, a thorough inspection of your suspension is in order.
If everything is solid, try removing your front driveshaft and see if that solves the problem. There are other culprits for such a broad problem, but if it's worse in 4wd, I would start there.
Another member here has actually removed his rear shaft, and that was his culprit.
Personally, I know the front shaft is my culprit, but at 45 mph the vibration goes away when I turn on 4wd, then gets worse when I go over 60 mph.
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
Good advice
I've had the front driveshaft go bad on an 02 QX4 4wd, swapped it out and was back in business. Also check driveshaft center support bearing for tears.
