Edub1 wrote:What's the deal with ignition mods? My ignition works fine and boosting brings things closer to energy of activation to begin with. I've also seen a study, although I don't think I could find it again, that showed that all sparks are equal that are sufficiant to start combustion. That is to say that there is no difference in the spreading of a flame front or the speed of ignition. I assumed that the idea has always been to use the smallest possible gap to prolong the life of the plug.
What is the theory behind smaller gaps and why would you need a more powerfull spark when you are already closer to the point of activation?
Also, my friend authored 2 MSD patents and he told me that the point of an MSD is to ensure operation under the worst possible conditions. Using this for performance applications is simply hype.
They are for the worse possible conditions, and I would say that the increased combustion chamber pressures are pretty rough. The smaller gap allows for easier firing, and so less chance of misfire. A plug will only see as much voltage as is necessary to fire. But the MSD uses Capacitive Discharge, so that at high RPM it's saturation time is much less. This allows the oportunity for multiple spark (hence the name, Multiple Spark Discharge), although not an absolutely necessary feature, it does insure a little better burn. By bringing things closer to the energy of activation, you do not have enough time to fully saturate the coil at high RPM, this is why the box helps.
