350z wont start and dunno what i did wrong!!
Nissan 350z / Nissan 370z general community discussion forum
Antronig
Hey so i am not a noob in any way but i was changing one of the bulbs in my dash cluster on my 2005 covertable, and when i threw it all back together along with the steering column i noticed when i tried to start it it wont tun over.
I checked my bat power and chageed it more but its good, checked my fuses and i made sure i had only taken out the pin clip harness attachments so ther was no wiring issues.
I took my battery off many times and then hooked it back up and no change, it crancks hard and normal just wont turn over.
Only dumb thing is i didnt disconnect the battery when i swapped the bulb which i figured was no big deal, im thinkin do i have to reset the ecu? When im cranking the engine check light turns off so i dont think there is any codes.
any ideas?
R350Zz33
Car: 2008 350z enthusiast
take every thing apart you had apart and look for wires that you may have disconnected
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
you could try the ECU reset process, and tps reset.... it won't hurt anything if it doesn't work.
zer...99577
GL
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
might be helpful to check for codes as well
C-Kwik
Sounds like it has something to do with the immobilizer.
AZ350Z
Car: 2003 350Z Black
C-Kwik wrote:Sounds like it has something to do with the immobilizer.
Yup, try your spare key before you tear back into it.
phyzicxz
distributor maybe?
R350Zz33
if it was the immobilizer it would start for a second and then die right ?
CREEPINGONCHROME
Car: 2003 350Z TOURING
no it would just turn over with no start!and 350zs dont have a distributor.
R350Zz33
i herd the immobilizer if not present will allow the car to start but then die in like 2 seconds
CREEPINGONCHROME
i have a unprogrammed key i keep in my car it will turn over but wont start!
xjmxstac
Car: 2003 nissan 350z track edition
phyzicxz wrote:distributor maybe?
You've gotta be kidding me...*edit* nevermind, I can tell from your sig...
+1^ on the immobilizer. sounds like an issue my friend had on his tundra. He got a duplicate key for his 06 tundra tried it out. Engine turned, but no ignition.
Modified by xjmxstac at 4:45 PM 3/12/2009
Return to “350z / 370z Discussion”
