R350Zz33 wrote:does it get fogged up if it does you should listen to me i daily drive my z so i have alot more info then someone who dosent even own one.
Well let's see your infinite wisdom about this subject Richie.....
I'm gonna have to agree with snwbrdr, check your heater core. The same thing happened to my friend and his '78 L82. Same symptoms as you described. If you must use the car in cold conditions, try cracking the window open just a bit, enough to let some air in to circulate in your cabin until you find a fix.
Now, when you select the windshield defrost on your climate control cluster, where does the air come out of? It should be coming out from the front of your dash (right under the windshield).
