eflihaweopifhwao »
https://forums.nicoclub.com/eflihaweopifhwao-u316821.html
Mon Oct 13, 2025 7:44 am
Thank you for your response. So, following your method, I dont need the TCM anymore right? During the manual swap process, in terms of circuitry, I only need to reset the wiring for the Clutch Interlock Switch and the backlamp, and then it's basically done, correct? Regarding the backlamp, combined with your replies in other posts, I think I have found the correct location. I’ve attached a simple diagram and hope you can confirm it for me. These two connectors are actually right next to each other, right? I have a rough idea that they should be under the passenger side, but I’m not sure if what I’m saying is correct. I apologize for constantly checking with you; I know nothing about car circuitry, but I’ve been trying to learn about it recently.
