350Z VK56DE swap???
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
StockSC300
Car: 1989 240SX with a Supercharged 1UZFE V8(yes a vortech on a toyota V8 in a nissan... I know)
Hey I'm wanting to know, why more people aren't doing these swaps??
Is this just an unpopular thing, or is it that people are terrified by the amount of fabrication involved in the conversion??
I shouldn't be that hard if you have a MT Z car...
There are adapter plates on ebay for sub: $500
http://www.ebay.com/itm/VK56-VK56DE-ADA ... 9a&vxp=mtr
mounts require a mig welder: $400
http://www.google.com/products/catalog? ... CHoQ8wIwAg
Misc steel for fab'ing: $200
Drive shaft at: $400
Flywheel adapter $400
Stock Z Clutch $free
Headers (supposedly..) $300
Misc parts, and random necessities $100-$3000
So the total without the Misc parts comes to $2200
That is less than a tax return for most Z-owners.. which isn't bad for a V8 350Z car this of course DOESN'T include the cost of obtaining a motor, or exhaust but all-in-all that still isn't bad for a swap.. 380 worth of V8 torque. which is a decent platform to start something awesome, and an Awesome sound at that!!
So why aren't more people doing this??
ManDogFish
Car: 350z ... 2004, maybe 2004.5, dno
6mt
base model
It is a better option...ur car will be unique and will hold value if done right ...
In many places that would not be a road legal car unless declared and paid more insurance for...
people risk it with civics cuz the car is not worth much...
but the main reason is...cuz
Mechanically inclined creative people "usually" go in a field that goes with their skills... many being mechanics, some technician, some trained technicians and a few engineers in mechanical/manufacturing...they dont earn tooo much
"Most" of the time the people who make enough to buy a 2 seater as a second car are not mech.inclined...
very few are and they lead many of the aftermarket developments..
As the value of the car goes up...the mechanical intuition of the owner usually goes down and hands on skills definitely go down...
Im summary...they dont kno chit... it could always be worse, can be observed from M3 or S4 forums...
ManDogFish
6mt
base model
how much do you think it should cost for the whole swap over a year or 2??
basically buying parts whenever you find them at good prices (used)...
StockSC300
I think I might have listed this all before, but this would be a close estimate.
ManDogFish
6mt
base model
I was looking for more details on the miscellaneous parts and engine cost
On ebay, VK56 are going for near $2000...
It might be possible to fit a 300zx transmission to the engine...
the ECU will be required...
I think it will cost that at the minimum if ur miscellaneous includes the ECU, compatible transmission, custom exhaust, maybe custom oil pan and the sensors to go with it..
ManDogFish
6mt
base model
before I got the 350z...I wanted to buy a 1991 BMW 850ci and swap a 1UZ-fe into it...
low on gas, cheap to maintain, possible to modify....it would be a car I could drive 250,000kms...opposed to a V12 850ci that barely gets driven 10-15000km/year
how much did it cost you to swap the 1UZ-fe in?? how did you connect the tachometer and the rest of the sensors from Nissan to Toyota?? which transmission, driveshaft and rear diff did you use??
StockSC300
Oh that was easy, after I figured out the adapter plate stuff, everything else was just peanuts. the wiring was a joke with the 1UZ. you can connect 6 wires and the engine will start. the motor mounts were pretty easy. the transmission was off of an SR20DET 4cylinder engine, the tachometer was just connected with a tach adapter box from MSD, and the majority of the sensors that toyota uses went directly to the ECU, but Toyota has three coolant temperature sensors in the engine for different reasons, but for the instrument cluster I just used the one from the nissan on the coolant boss on the toyota engine, and everything worked..
Super easy.
Rear differential was stock, and the drive shaft was a custom one-piece.
Return to “350z / 370z Technical”
