350z transmission swap? for sr20det
drifterdevin
Car: 1985 toyota corolla, 1991 nissan 240sx, 1994 nissan sentra, 1991 infiniti Q45
I hear that you can swap the 300zx tt transmission for the sr20det trani, so can you swap the 6 speed 350z trani to the sr20det?
turbo2nr
Car: 97 240sx (kouki)
ive been looking into this as well, as of right now the answer is no. you need to fabricate a custom bracket, and mounts ect.. lots of work and a custom clutch ect.. lots of work
it would be sweet to have a 350z 6 speed, but i think you would have to get the 350z diff as well . the short 4.08 gears and the close ratio 6 speed may be too short imo
cody180sx
Car: s14 rb25det fully built 550whp coming soon
i asked this question like 2 weeks ago didn't get anywhere with it
zerothread?id=393552
sprintman
Car: 1992 240sx vert 1989 Porsche 944
idk about the sr but i do know that Xcessive on enjuku makes and transmission adapter and shifter relocater for the ka engine. for the 300zx to ka. not 350z.im sure some one has fabed one up somewhere. if not....do it and be the first one.
Boosted Gator
Car: 1996 240sx w/ SR20det redtop
I am not sure about that yet but I did read in a magazine that nismo has a 6 speed built for the SR20 and comes built up to any specs you want.
cody180sx
yeah i saw that to in d sport like a month are 2 back about a nismo 6 speed for a s15 and hks makes 1 for the sr20 but it's like retarted expensive here it is
http://www.hksusa.com/info/?id=2081
it is a bad azz dog gear transmission but is 13000 dollars for the 5 speed and another 1300 for the 6 speed i was tring to get away with not spending that for a transmission
drifterdevin
my buddy has done a 350z drivetrain swap, so as long as the vq and the sr 20 det are close to the same size you sould be able to use the mounts they use in the kit, and the shifter relocator. is the 300zx and 350z the same motor block? i know that the VE and VG are the same blocks, how about the VQ block?
M-180SX
Car: NISSAN 240SX AND DATSUN 240Z
I have the 350z transmission on my SR20DET for a long time ago. It works fine and with some imagination it can be done.
You can see part of my swap here:http://www.cardomain.com/ride/481486/2
The input shaft need to be cut in order to use the stock flywheel and clutch. At the end the car. Sorry my page is in spanish.
M-180SX
son pics
Johnnydrifter22
Car: 1990 S13
Full Race has been using a 300zx TT Trans on there SR20 for quite some time. I think last time i spoke to them they were going to swpa to a 350z trans, but i know the 300zx TT is stouter. Contact them and ask.
jonathandavis04
Car: 95 240sx se
hey how did your mpgs change with the 350z transmission behind?
M-180SX wrote:son pics
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
He cut the bell housing of one trans that mounts to the motor and cut off the front of 6spd trans and welded it back together, not easy to get straight/lined up.
I thought about taking a KA auto trans housing and getting it machined to mount to a machined 6spd trans. but then the rear diff gear is gonna be wrong, you won't have a speedo unless you use 350z axels and sensors. Correct me if any of this is wrong, but the trans mounting might be the easiest part of the swap. everything else is a custom event. Look up the Kid and his dad that built the full 350z drivetrain into an s13, look how they mounted the diff and tell me you want to dive in to that project. I don't have that kind of time.
And unless he is using the 350 diff its not gonna be fun to drive, much less care about MPGs.
