350z transmission in a 240sx
LambJerky
Car: 1995 240sx
Hey, so I've been interested in buying a 240sx. I found a 95 for sale, only problem is it's auto. Then, I also found a transmission for a 2001 350z. Anyone know if I could switch in a transmission from the 350z for the swap? Thanks.
deh3000
just swap the 240sx transmission. it will line up and all the parts you need are easy to get. http://vqswap.com/_wsn/page3.html. see how the housing is to long you will need to shorten it like what they have done but i dont even think that the z33 trany' bolts will line up with the ka24ed bolts
irax
Car: VQ35DER Powered S14.3
wtf are you saying? deh3k?
it won't line up magically.
it can be done but you need an adapter plate, and a drive shaft. you will also need some sort of shift linkage like in the weld s14 car
even if you use the 6speed from a vq40 from a truck you will still would not fit correctly. honestly fitting the 5at transmission would be a easier task.
