350z track rotor conversion? how well dose it work?
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
hey everyone, i currently have the 300zx 30mm front calipers and rotors on my s13, im looking to do the 350z track rotor conversion for my current set up, has any one here done this conversion? how do you like it? i have the brackets to move the calipers out so all i need are the rotors, my friends dad can redill the rotors via his machine shop. im just wondering has any one has experience with this setup? hopefully positive!!!!!!!!!
thanks for the help!!!!!!!!!!!!
I have it on my 'vert. Love it.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
^^^^pics or GTFO!!!
I thought of doing this on my s13 as well...
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
I would like to see this, as well. I've been eyeballing the 350z track rotors for my front to compensate for the upgrade to wider r-comp tires.
94_240sx
Car: 94_240SX
Well, I went directly to the 350z rotors, so don't know the difference, but I like it a lot.
jr_ss
Car: 95' S14
I have them on my S14 as well, using Hawk HPS pads, they work awesome...
Modified by jr_ss at 10:24 PM 4/27/2009
addisonblck
Car: 93 se mods soon to come
Sc300 1jz swap laundry list of goodies
wow...i like
94_240sx
Car: 94_240SX
Mine's done with Project Mu pads. Search suspension forum. I did a detailed write up.
EDIT: Adding the specs.PowerSlot 350z Track Rotors from Autoanything.comAnodized black JSK Adapter kitZ32 Aluminum 30mm calipers powder coated by trgcoating.comProjectSilvia s/s brake linesProject Mu B-Force pads
Modified by 94_240sx at 8:38 AM 4/28/2009
kouki munster
Car: 97 base 240
I to am rocking the z track rotors with project mu pads.
sloweighty
Car: sileighty
94_240sx wrote:Mine's done with Project Mu pads. Search suspension forum. I did a detailed write up.
sorry to thread jack but are those really nismo wheels and if they are then do you have the part number for them
xX RB Xx
Car: SE3P, FC3S, FC3C.
nooooo
those are fake rotas with nismo stickers.
sloweighty
Car: sileighty
xX RB Xx wrote:
nooooo
yea that what i thought too but i wasn't too sure. I have been trying to find nismo wheels for my 4lug but i cannot seem to get a part number for that model wheel
94_240sx
Car: 94_240SX
Well, they are not Rotas.
Here's the part numbers for the Nismo wheels. I have part # for the 16 inches too, but you don't want them. 350z rotors need at least 17 inch wheels.
- About 60,000 Yen each)17x7.5 +20 4-Lug 40300-RN856-W (White)17x7.5 +20 4-Lug 40300-RN856-BR (Brown)17x7.5 +20 4-Lug 40300-RN856-S (Silver)
17x7.5 +30 4-Lug 40300-RN857-W (White)17x7.5 +30 4-Lug 40300-RN857-BR (Brown)17x7.5 +30 4-Lug 40300-RN857-S (Silver)
- About 65,000 Yen each)17x8.5 +35 4-Lug 40300-RN858-W (White)17x8.5 +35 4-Lug 40300-RN858-BR (Brown)17x8.5 +35 4-Lug 40300-RN858-S (Silver)
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
i love my setup...car stops on a dime literally
EBC gold cadmium plated 350z track rotorsr1 wurks 350z adapter kitnissan 300zx aluminum 30mm calipersagency power s/s brake lines
pic when i first installed them, before plating wore off
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I actually took mine off yesterday and put the standard 300zx rotors on. I was having issues where the inner pads was rubbing more. I think it was the brand of conversion brackets.
The think I dont like about it is since the Z32 calipers and pads are designed for the z32 rotor they dont fully fit the Z33 rotor. At the top corners the pad surface actually doesn't make contact with the rotor.
I am going to put them back on once I order a new set of brackets. I have the R1 wurks brackets and they suck. Helicoil ripped out, machining is off.
94_240sx
Car: 94_240SX
OutToWinPAHC wrote:The think I dont like about it is since the Z32 calipers and pads are designed for the z32 rotor they dont fully fit the Z33 rotor. At the top corners the pad surface actually doesn't make contact with the rotor.
Yup!
OutToWinPAHC wrote:I actually took mine off yesterday and put the standard 300zx rotors on. I was having issues where the inner pads was rubbing more. I think it was the brand of conversion brackets.
Try JSK brackets. I was impressed by their quality. They fit perfect.
newdude1
How much does this set up cost?
sloweighty
Car: sileighty
94_240sx wrote:another thing 94_240sx what kinds of wheel spacers are you running? and where did you get them
94_240sx
Car: 94_240SX
newdude1 wrote:How much does this set up cost?
Just do some search on these and you have ballpark figure.
30mm calipersRotorsBrackets Brake linesPads
sloweighty wrote:another thing 94_240sx what kinds of wheel spacers are you running? and where did you get them
15mm Ichiba spacers with 60mm Nismo studs. Wheels clear calipers without the spacers though. They don't vibrate at high speed, so quality is very good.
http://ichibausa.com/5mmalwhsp3.html
sloweighty
Car: sileighty
any problems with them yet?
xrproto07
Car: 96 S14 zenki
Sick i might have to try this on my S14....
SullivanRacing06
so are the 350z track rotors 30mm wide or 26mm wide?
i got the adapter brackets for free so the only thing ill have into the entire brake set up would be are the rotors, mabey 150-200 tops?
hell yea!
mattblancarte
Hmmm, this option looked okay until I saw that part of the pad is off the rotor. No-go for track use. Oh well... the 13 inch wilwood front kit at $1300 shall suffice.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Yeah you actually loose pad surface area which is less effective. But at the sae time you get more cooling surface space. Its a lose win case.
splintercell
weird ive enever had a problem with mine. ill take the wheels off this week to double check everything. i too have r1 wurks adapt
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Yeah mine were bad form the get go. The one helicoil was beat up right out the box. The when checking the measurements its was off a few 1000ths from where it should be causing the one caliper to sit further out and pressing the pad into the rotor.
It was too the point where when the wheels was torques and the vehicle jacked up you could not free spin the front right wheel.
I took the brackets off, put 300zx rotors upfront and the issue is gone.
I am going to put the 350 track rotors back on after I replace the brackets with another brand.
splintercell
OutToWinPAHC wrote:Yeah mine were bad form the get go. The one helicoil was beat up right out the box. The when checking the measurements its was off a few 1000ths from where it should be causing the one caliper to sit further out and pressing the pad into the rotor.
ok...gotcha. i need to invest in some better pads mine leave hellacious brake dust.
94_240sx
Car: 94_240SX
sloweighty wrote:any problems with them yet?
No problems at all with brakes and spacers. I'm a very picky guy and I have no complaints at all. I wish I had experience with z32 rotors and moved on to 350z rotors, so I can tell the difference.
SullivanRacing06 wrote:so are the 350z track rotors 30mm wide or 26mm wide?
30mm aluminum or iron calipers and 17 inch wheels are REQUIRED.
Where is RB20DETTod? I haven't seen him forever. I've wanted to have it ever since I saw his car. He has SPL brackets.
Modified by 94_240sx at 7:54 PM 4/28/2009
sloweighty
Car: sileighty
no.........i am sorry i was talking to 94_240sx about his wheel spacer cause i wanted to know if he has had any problem with them yet
hai1206vn
Car: 95 s14 se
jr_ss wrote:
sorry for yelling but WHERE DID YOU GET THE OHLINS FROM???
