redsx13 wrote:If by "hatch" you mean the plastic sub woofer cover behind the drivers seat, then yes. simply pry it off from the bottom. start near one side,and use a flat screwdriver to snap it off. its just held on by 4 clips. After the cover is off, use a 10mm to take out the sub( dont use a screwdriver cuz it will strip the bolts)
if you wanted to take a look at the amp, its located in the trunk under the left hand side foam cover.
good luck
lol - worried about stripping the bolts but you're going to make him snap the tabs off at the bottom...definitely just use your fingernails or something soft to get the edge and gently pry it from left to right starting just below the top left corner. it will just pop and pull out from the top when you get it out enough---
