350Z steering wheel on a 300zx
240sxjeff
Car: nissan 240sx zenki version
I was thinking about removing my 93 300zx steering wheel and replacing it with the 350z steering wheel. I want to know if anyone has done this yet and if the 350z wheel bolts right up in the 300zx.
freakonaleash1187
Car: '93 300ZX N/A, '97 200SX SE
It can be done with enough work, but it is most likely not a direct replacement. I had a really hard time switching my airbag steering wheel to the bagless steering wheel.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I figure the biggest issue is the hub splines, I know all 70-83's used the same spline and are interchangable, if the splines engage then you can bolt on the wheels, and I assume all airbags are 12 trigger with a body ground, even if the connector is different a single wire you can simply swap the lead to make it plug in, the best thing it to locate a used wheel and try fitting it and see how it works out, either it goes on or it don't, then you could always cut out the hubs and weld in the correct hub to make it fit
