350z springs on g35
av8or
Car: '07 FX35 AWD ... '06 4runner limited ..... A320 F.O. (my other ride)
is it correct that a '06 350z springs and shocks on a g35 coupe will drop it a good inch front and back? right now i have 20's and have a 2 finger gap between the fender and tires, tenabe nf210 gives an inch drop up front and .06 at the back... should i go with oem 350z springs or just get the tenabe? as far as camber, which one has the least impact?
biggie
Z33 springs will only be a 1/2 inch drop on a Coupe.
And if you only have a small gap with stock springs you wheels/tires have probably thrown off you speedo.
The lower you go the more it will affect camber. Z33 can be aligned with stock camber adjustments. Not sure on the Tanabes.
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
I have the 06 350z suspension on my G and it is a great upgrade. I love the way it makes the G look and how it drives. You still have a good ride it is just a little stiffer than before!
I don't know if i would do it for just a .5 of an inch drop though. On the sedan it gives you a 1 inch drop.... But then again if you drop it more than .5 it will rub on things in the road because it will be so low.
Good luck.... Oh and it is a very easy install took me 1.5 hours!
DJ
av8or
Tampa G35 Sedan 6MT wrote:I have the 06 350z suspension on my G and it is a great upgrade. I love the way it makes the G look and how it drives. You still have a good ride it is just a little stiffer than before!
DJ
so it's a direct install on the coupe as well? how many fingers of clearance do you have right now?
Tampa G35 Sedan 6MT
Im not sure what you mean by finger clearence... If you have stock size wheels and tires.. you will be fine... direct bolt on!
av8or
Tampa G35 Sedan 6MT wrote:Im not sure what you mean by finger clearence... If you have stock size wheels and tires.. you will be fine... direct bolt on!
how many fingers can you stick between the fender and wheels, front and back... and i moved up to 20's... 275/30's at the back and 245/35's up front... will i have some rubbing issues with the Z33 springs?
Tampa G35 Sedan 6MT
They new shocks travel up and down less than the G shocks and they only allow for the wheels to travel up so much so it won't rub the inside. and if you don't rub with 4 people in the car now it won't with the Z suspension.
DJ
av8or
went ahead and got the tanabe nf210... 1" drop in the front and .06" rears...1 finger clearance between all fenders and tires..
Modified by av8or at 12:30 AM 8/1/2009
