350Z spring and shocks on G35 Coupe
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
biggie
Ok, never found a clear answer or example on this.
Looking into Z33 springs/shocks on my G35 Coupe. Believe it should lower about 1/2 inch. Confirm?
Anyone with before/after pics of this on a Coupe?
And if I go this way I do plan on the revised shocks. But should I do the unrevised (softer) or revised (harder) springs? I've seen the unrevised recommended, but would have thought the revised would work better on a heavier G compared to Z33.
Thanks
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Yes the z springs will drop the coupe an additional .5". I would go with the revised setup. The unrevised setup 03-04 had softer springs in the rear than the revised, but the shocks weren't dampened properly and caused a bouncy ride. The revised had stiffer springs and properly dampened shocks for the rear. The front spring rates didn't change.
biggie
Thanks. I'll be looking around. Seems like most think the Z33 stuff has gold in it or something lately.
Saw Nismo set for $700 today, way too high to me.
RED_DET
Vendor
2011 Infiniti G37x
Nismo is the bomb, I run it on my sedan. $700 is a deal if its new.
biggie
RED_DET wrote:Nismo is the bomb, I run it on my sedan. $700 is a deal if its new.
The stuff from the Nismo Z33? Its that great?
Its used, but was in good shape. But I can' afford that much for a 'stock' setup.
RED_DET
Vendor
2011 Infiniti G37x
I absolutely love the suspension, especially coupled with stillen adjustable sways.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
