350z rims?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
johnparkyourcar
Car: 03 DG coupe 5AT
I dunno if this has been asked before, but has anyone put on the 18x8.5 and 19x9.5 350z rims on a g35? I had no idea they were Rays and only found out when I saw my friend's Z a couple days ago...
I was thinking of Volk SF-Winning but I kinda like these too... any thoughts?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
they would fit perfectly on the coupe. they would fit on the sedan, but with a bit of a stretched tire in the rear though.
JeromeS13
Car: 2008 Subaru Impreza STI
I will soon be running the rears (18x8.5 +33) all around on my car with 245/40/18. Hell, you can't beat them for ~18.62 lbs each!!!
Just keep in mind, if you pick up a set, they're staggered; 18x8 +30 front and 18x8.5 +33 rear. I picked up two sets and sold the fronts.
:D
EDIT: Doh! I didn't even look at the picture... I thought you were talking about the V1 Track Model wheels...
Screw those new ones. They're heavy as balls!!!! 21.25 lbs front and 29.50 lbs rear!!!!
V1 Track wheels FTMFW!!!
logicmobile
Car: infiniti g35 sedan
hi there, just a question about the rims installed on that sedan with aero package???what brand and model is that?? look tight!!
johnparkyourcar
Those are actually stock 350Z rims. I've seen pics of them on coupes... the fronts are way tucked in and the rears look ok so on a sedan I would guess the fronts would fit well but the rears would run into rubbing issues...
twin001
Car: 2006 G35 Coupe, 6MT, many mods!
Those are stock on the NISMO 350z, the fronts are 18" and the rears are 19".
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
