350Z Rear Subframe Bushing Kit
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
AZ350Z
Car: 2003 350Z Black
I recently installed the Whiteline rear subframe bushing kit in my 2003 drift car, thought some might find it useful on here.
Finally getting around to replacing the rear subframe bushings...
The new bushing kit:
Couple shots of the subframe dropped:
AZ350Z
Another couple shots of the subframe:
Sawzall to cut out the rubber liners:
Crap OEM bushing removed:
AZ350Z
Rear subframe bushings in:
Notice the pole jack supporting the front of the car, very important:
AZ350Z
Front Subframe Bushings:
AZ350Z
Subframe back in car:
I can tell you the stock bushings were completely worn out and these make a huge difference in the way the car drives and drifts. Highly recommend this to all who track or agressively drive their Z's or G's.
AZ350Z
Feels great on the track too...
jasontamu
being a drift car, you didnt care to go solid???
http://www.sikky.com/view_item.php?id=147&catid=14
-J
dasoupdude
Car: 2005 Nissan 350Z
That's what i was wondering a while back..
I remember reading (i think it was your article) about it a bit ago.
AZ350Z
Yeah, I debated going solid with them but I have the solid diff mounts and bushing and thought it would be too much. I still DD the car too.
acidjake75
Car: 05 DB Z
Very nice thread! This helped us install the SIKKY solid subframe bushings on my buddies car...
jasontamu
AZ350,
You may wanna watch the shop doing the work on your car man......
both calipers hanging by the oem rubber lines???, drive shaft hanging and getting scratched from exhaust flanges, not protected from being damaged....remember its a Carbon fiber drive shaft....
also, you may wanna build a diff catch can, you can see all the residual diff fluid and dirt residue on your subframe......maybe even a quick fill port..
-J
webf2011
The pictorial representation tells more about the installation process than the words. I was planning to install the same with my 2005 350Z. I just wanna know whether it will suit for my car?
Return to “350z / 370z Technical”
