Wow! Looks great!carbon z wrote:Brakes you want, brakes you get.
Yup, has to be...that's the only year they offered E33.Nismo24zero wrote:She's a 05
Lower it and DO NOT get spacers. If you want your wheels/tires to stick out then get the right wheel with the right off-set. Spacers should be the last option.kuhan wrote:^lower it and get spacers.
They force the wheel to set out farther without changing the CG of the wheel itself. This increases vertical torque on the wheel bearing and other components, causing them to wear out faster. Think of it like a simple lever. The farther out on the handle you apply force, the greater the amount of torque on the opposite end. The wider the spacer, the greater the force applied. Also, some service departments (auto repair places) will not work on your car if you have spacers. Something about it being a safety issue – not sure why.kuhan wrote:What's wrong with spacers?
Retired Chief wrote:They force the wheel to set out farther without changing the CG of the wheel itself. This increases vertical torque on the wheel bearing and other components, causing them to wear out faster. Think of it like a simple lever. The farther out on the handle you apply force, the greater the amount of torque on the opposite end. The wider the spacer, the greater the force applied. Also, some service departments (auto repair places) will not work on your car if you have spacers. Something about it being a safety issue – not sure why.kuhan wrote:What's wrong with spacers?
I love white cars I just wish they weren't so hard to keep clean (better than black though!).NewBzer wrote:New to the site and the tuner world. Still pretty stock 05 base. In the near future borla exhaust, and nismo body kit.
lol.TangeloZ wrote:Great Pics everyone!
