350z limp mode
Nissan 350z / Nissan 370z general community discussion forum
StricNyne
hey my friends 350z goes in limp mode constantly after supercharger install. all wires were triple checked, there is no vacuum or boost leaks, it used to happened after a few miles but now since its warmer outside it starts on initial start, where we cannot rev it past like 4500rpm, we replaced the MAF and it still has problem, next we were told it could be a possible 02 sensor issue, we are going to work on that next but this is a 04 z with like 40k miles how can it be the 02 sensor ? anyone have any input on this issue ? the only thing i can think of doing it changing the vortech split second box, also the plugs look awesome
StricNyne
also car has no cats, only other mods is borla true dual exhaust, and rps clutch fw combo
StricNyne
bumpage
tiger
sure you have the vac lines right? Could be a little tiny mix up somewhere...
StricNyne
only 2 vac and thats for fpr, and bov i ted off one in the front, is there supposed to be a vac line DIRECTLY to the splitsecond box ?
tooskerdo
Car: 05 350z track. ultra yellow, kit, blower, exhuast
Mine did the same thing and it was the throttle body. although i could'nt rev over 1500.
StricNyne
what did you do ?
sirg
Car: Camaro
I have a thought or two on the subject. First of all, we have a Z here with an add on supercharger that normally runs like a bat out of heck. Problem is that it would go into limp mode if it were to tach over 5 grand. We did the MAF and a pop off valve but it still does it.
For some reason i get a red flag when i look at the setup of this thing. With the superchargers i have seen, the MAF would go before the supercharger, not after it. Is it possible that the supercharger is pushing too much air past the MAF for it to handle? In other words, the volume of air flowing past the MAF is beyonf its programed range causing it to go into limp mode.
How many other people are having this problem and has anyone figured out a fix for it.
audtatious
Yeah, maf position seems to cause problems from time to time. They are very sensitive to the point where some Maxima owners (with the same VQ35DE) had to replace their maf within months of installing an aftermarket intake.
StricNyne
we bought a BRAND new maf and still same issue, tuner said possibly its the 02 sensor... just dosent make sense
StricNyne
might have to use utech
audtatious
StricNyne wrote:we bought a BRAND new maf and still same issue, tuner said possibly its the 02 sensor... just dosent make sense
The question posed from the prior poster was the location of the MAF. Before or after the SC.
StricNyne
after the SC its liek right before the TB
Corradoslc7
Car: 2008 Nissan Xterra VQ40DE
Stop guessing at what might be causing your problem, go to pepboys or advanced auto and get the car scanned. Then at least you will have an idea of where to start, because the car could be going into limp mode for any number of reasons. Good luck.
StricNyne
i got a scanner just my friend has it imma get it back tommorrow
sirg
Car: Camaro
Scanning it will not tell you anything about whats going on with it. It does not set a check engine light or store any codes when it goes into limp mode.
Update.....
We have been in contact with the people at Vortec and, as per their instructions, removed the black box today (yes, there is a vac line that goes directly to the box) and are shipping it to them since they think it may need to be reflashed. Ill let you know how it turns out once we get it back and reinstalled in the car.
StricNyne
ok sounds good
StricNyne
code is p0335
Corradoslc7
sirg wrote:Scanning it will not tell you anything about whats going on with it. It does not set a check engine light or store any codes when it goes into limp mode.
StricNyne wrote:code is p0335
Well it seems that StricNyne found a code P0335, which is for a faulty crank position sensor.
StricNyne
what does a cpd go for and i love corrados btw !!
Corradoslc7
StricNyne wrote:what does a cpd go for and i love corrados btw !!
Not sure on a price, I would just give the dealer a call. Yeah I used to have a 1993 slc, it was awsome, but now I'm driving a Golf R32 untill the next gen 350z arrives. Good luck fixing your friends Z.
StricNyne
u going to HIN this weekend if so u might be able to see his z
Nick240sx
Car: 2009 Ford Fusion SE Sport
StricNyne wrote:u going to HIN this weekend if so u might be able to see his z
apparently ill be there.
StricNyne
is nico doing a grp meet there
Nick240sx
StricNyne wrote:is nico doing a grp meet there
not to my knowledge, im goin with some buddies around here. I still have to justify the $30 price and whether ill b willing to stay till midnight. however, if i do have the energy and the spending will, ill be hittin up HIN and then clubbin afterwords.
StricNyne
sounds like a plan we should all meet up man i got liek 10 friend who wanna go most r nissna owners
StricNyne
maximum bumpage
sirg
Car: Camaro
We got the control box back today. Monday ill install it back in the car and let you know how it turns out.
StricNyne
thnx man !!!
StricNyne
ne news sirge
Return to “350z / 370z Discussion”
