350z interior
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
orangeNblue
Car: 2008 Nissan 350z
Are the interior parts from the 2006+ 350z's able to fit into the 03-05?
The only parts I'm interested in are the center console on back to where your arm would rest. The all the pieces from where oil pressure, volt meter gauges (etc) are to what is basically the glove box/armrest of the 350z. I was wanting to make the change purely for aesthetic reasons and to replace the one I have now which is slightly messed up....and I like the way the 2006+ does the cup holder with the piece that slides back
I didn't know if you could put those parts into a 2003 or not and I couldn't find anything on the internet
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the chassis is the same so it should swap, but how many parts are needed to make the swap
orangeNblue
I think that there's three main parts-the center console itself (part where the gauges, climate control, and radio are)-the part around the shifter-the part from the shifter to the place where the cup holders can go now...and then all the small pieces that fit in with them...
so basically the whole center section is what I was curious if you could swap between to two. I wasn't sure if you were able to bc the heating seats buttons and the hazard light are in different places
sluggoZ
Car: 2004.5 Nissan 350Z Touring Roadster Super Black/Black
From what I could remember is that the '03 thru '05 is OK to swap but that's it!
orangeNblue
really?? thats kind of a bummer...
I really like the set up in the newer ones...is this for fact or are you definitely sure that it wouldn't work?
sluggoZ
orangeNblue wrote:really?? thats kind of a bummer...
I found this for ya.....a lot of reading to do......http://my350z.com/forum/exteri....html
orangeNblue
Thanks for the find. So atleast now I know its possible to change the climate control and shift knob assembly....I'm pretty sure the rest will as well. I'm prolly going to check out a junkyard this week and see if I can find the pieces...
Return to “350z / 370z Technical”
