350z Immobilizer Issue-
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
Shades
Car: Nissan 350Z ' 05
Hey Yall,
So I have been lurking for awhile, and it seems a lot of people have the same issue I do with the immobilizer not turning off when trying to start the key.
No one seems to have the cure for this, and mine is getting worse over time. I want to get it fixed. It has already been to the stealership twice. The replaced the NATS antenna and that only helped for a little bit.
I am looking at two solutions.
1. Find a Up rev tuner in North East Ohio to turn off my immobilizer in the BCM.
2. Install Xpresskit XK07 into the ECU to overide the Immobilizer. This is the same thing they use for remote starts, but hardwires into the BCM instead of jerry rigging a key signal in the ignition like most bypass kits.
Any ideas of suggestions of tuner shops never Cleveland would be great.
Keith
dasoupdude
Car: 2005 Nissan 350Z
I suggest finding an UpRev Osiris tuner, thataway you can get your car tuned and have your immobilizer disengaged.
Return to “350z / 370z Technical”
