350z headlight interchangeable?
Nissan 350z / Nissan 370z general community discussion forum
94_240sx
Car: 94_240SX
Car: 2003 350z with HID headlights
I have two questions:
1. Can I install 2003 regular/cheapest headlights without wiring modification?2. Same question to 2007-2008 headlights. Are they going to be a direct swap or is wiring modification required?
Thanks!!!
tj_rossiter
Car: 350z
when i got my 03 it had 07 up lights frount and back doesnt look like any modification
dasoupdude
Car: 2005 Nissan 350Z
If you are going to put the oem 350z assemblies on one that regularly had the xenons, there would be slight wiring modification. And vice versa.
Same goes for the 07-08. Theres not really any drastic wiring modifications.
(goes for swapping tail lights too!)
CUSHLOS
Car: 05 350Z TRACK
it requires pin changing what i mean it u look at inside plug and pins r in diff position and also power pins and grounds r in diff spot on both old and new u just need to test light to see were power pins r and then macth w/eather headlights so u have power to them hope that helps pretty easy not hard at all shop probley chard 50-100 bucks id do it 4 420 duby or a 6 pack gl bro
Return to “350z / 370z Discussion”
