350z has no power!! pls help!!
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
taystrippy
Car: 2008 350z GTM TT
spun out in my z and hopped up on a curb, in the process my right turbo's intake got ripped off and the car shut off completely. got it home and I have no idea what is wrong. car has no damage but I put my key in and turn to accessory and the dash has no lights and I do not hear my fuel pump prime. the car is basically dead. I put a jump box to my battery and still nothing. anyone know of any important groundings or sensors that may have gotten messed up? thx for any help.
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
You need to get under car and see what the intake would have struck as far as wiring, as you may have torn some of it up. Repair that then go looking for various blown fuses which would have blown out at the damage.
CarGuy87
Car: 350z, G37s, M35s
Well if by "right turbo" you mean passenger side then on that side are most of the electronics that can cause issues like you describe. Start with the basics by checking the harness in the battery/fuse/relay area and work your way out from there.
Return to “350z / 370z Technical”
