Q45Tech,How is a CofF value assigned for a certain tire on an ABS system? On different surfaces wouldn't the CofF be significantly different ie; pavement, concrete, wet, snow...
When ABS systems distribute their assistance is how they apply braking forces always the same? In other words, does ABS always apply the same force, duration of force and time between force pulses?
Now once CofF is increased, both on the software level and the ACTUAL CofF, what actually changes in the way ABS is applied? Is duration of force increased?
I'm going to start googling for more tech docs, but I figured I would go ahead and ask here.
Q45tech wrote:Steel has a very bad coefficient of friction worse than cast iron rotors."Asperities, which are microscopic projections from the "average surface," play a major role in determining the coefficient of friction between materials. The friction depends on the asperities of the surfaces in contact. The pressure on an asperity is greater than the normal force, that it may deform the contact area "plastically" (asperities can weld together). Therefore, frictional resistance arises from sliding objects breaking and creating bonds created by asperities. "
The Brembo greater thickness means the walls of the rotor are thicker by at least 25% each and so is the venting air space! This probably doubles the mileage to warping.
With grippier tires [than the Pilots] the ABS would need to be reprogrammed to get below 100 feet [60 to zero].
The[tire/road friction coefficient would need to go to 1.21 vs 1.08 currently.http://hyperphysics.phy-astr.g....html
