evildky wrote:how else you gonna put a better diff in wthout removing the old one?
I meant do you have to change it out when you change the final drive....
evildky wrote:most aftermarket carriers intended for the Z33 are intended to be used with cars that were equipped with factory vlsd (unequal output shaft length)(these interchange with Z32 n/a and 88SS Z31, S14SE) there are some specifically built for the base model cars (they have equal length output shafts) t(hese interchange with the 77-89 Z cars and S13's and non SE S14's as well as S12's)
back to the gear ratio, it all depends, thats why race teams will run different ratios at ifferent track, if you are leaving a given corner int he powerband right now you'll have to upshift to take the same corner whihc means you won't nbe int he power band anymore, if however you are exiting a given corner below the power band a taller rear gear will put you inthe power band for that given turn
most people misunderstand grearing and thing it's gives you mroe power everyewhere, ti just moves what part of the power band you are in at a given speed
I am looking for faster acceleration in general. If it changes the actions of the car as far as performance in and out of turns then i will reverse it or it just means its time for suspension to go a little faster thru the turn
I appreciate the help evil. I really want to talk to someone that has done this to there 350Z and looks like we have 0 replies as far as that goes....
spitalul2bad wrote:Sure. I'll buy this.
Please take pics and do a write up on the install. I would appreciate it - start a new thread about it tho and keep us posted about when you buy it and get it and when your installing it, please...
