NissanZ33 wrote:I'm sure it's on here somewhere, but after searching for a while I could not find anything about removing the 350z door handles. I have a black '08 Enthusiast and wanted to paint my door handles black. If anyone knows how to remove the door handles, or already has, would you be kind enough to link me some pictures or instructions?
-Thanks!
Driver door...1. open door2. locate & remove 2 rubber grommets right behind door handle.3. unbolt the 2, 10mm bolts holding the door handle in.4. pull up & out on the door handle to reveal that it is attached by 2 metal rods.5. flip the yellow or pink clip up to release the metal rod.6. unbolt the electronic key lock.
Passenger door...1. same except there are no metal rods to disconnect & no electronic lock done.2. there is a rod that goes into the linkage that is all. Just remove the rubber grommets & take the nuts off the studs that are made into the handle, lift up & turn a bit & they are off. 3. no need to take the door panel off at all.4. be very careful not to drop the screws down the door.
Good Luck!
