350z diff in s14 chassie?
turbo2nr
Car: 97 240sx (kouki)
First off i dont want to hear:put a j30/q45/ jdm vlsd/ kazz/ect..
i want to use a 350z diff cause i can get one for almost free...
so here's the info our cars use a r200 diff.the 240sx that came with vlsd uses a r200v.
the r230v is off the tt300z and doesn't fit, the diff is bigger.
the 350z/g35 uses a r200v
so in theory the r200v may be the same diff (dimension wise) as the 240sx.
can some one confirm this?
wost case can i fit a r200v diff from a 350z/g35 into a s14 r200 pumpkin?
thanks
Modified by turbo2nr at 11:25 AM 10/23/2008
Modified by turbo2nr at 5:30 PM 10/23/2008
ilovesideways
Car: 240SX S-13 KA24E
it's been done before, the only way I saw it done though was swapping the subframe.
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Not to thread jack, but, using the 350z subframe...will that bolt right up...I also have access to an entire 350z and the diff would be free.
gregfarz78
Car: 04 Honda S2000
97 Nissan Hardbody King Cab 4x4
09 Nissan Altima Coupe 3.5L
It fits but remember its geared differently, may require some custom work too its been discussed before can't remember where do a little searching.
Z33 - MT - R200 - 3.538Z33 - MT - R200V - 3.538Z33 - AT - R200V - 3.357Z32TT - R230V - 3.692Z32 - R200V - 4.083G35 - Sedan - AT - R200 - 3.357G35 - Sedan - MT - R200V - 3.538G35 - Sedan - AWD - AT - R200 - 3.357G35 - Coupe - MT - R200V - 3.538G35 - Coupe - AT - R200 - 3.357G35 - Coupe - AT - R200V - 3.357Q45 - G50 - R200V - 3.538Q45 - FY33 - R200V - 3.692R32 GTR - RB26DETT - MT - F160 - 4.111 - (Front Final Gear)R32 GTR - RB26DETT - MT - R200 (Mechanical LSD) - 4.111S15 - MT - R200H - 3.692S15 - AT - R200V - 3.916S14 - KA24DE - 4.083S14 - SR20DET - MT - R200V - 3.692S14 - SR20DET - AT - R200V - 3.915S13 - KA24DE - 4.083 - (Both R200 and R200V
RCA
For people wanting to use V160 6 speed trans from the Supra for their 2JZ swaps, the 350Z's 3.3 final drive will be curcial.
Hope some one figures it out
Modified by rcabrita at 3:59 PM 10/23/2008
gregfarz78
Car: 04 Honda S2000
Final drive in the Z33 isnt 3.1
zerothread/228683
turbo2nr
i know what the gear ratios are, thats why i want the z final gear.
but can anyone tell me if i can just insert the z pumpkin into my s-chassis?
i did do a search but only j30/q45 r200v comes up nothing about the z33 r200v.
RCA
For the record, I edited my post before I read gregfarz78's post
Great info on this thread so far
Modified by rcabrita at 4:26 PM 10/23/2008
ilovesideways
blacksrjdm wrote:Not to thread jack, but, using the 350z subframe...will that bolt right up...I also have access to an entire 350z and the diff would be free.
No...I'm almost positive it will not bolt right up. I'm pretty sure it would requige some fabbing skills.
spooled240
Car: kouki s14
theoretically, the internals should fit since they are both from the r200v housing. I've been told that the internals of a pumpkin are fairly universal as far as the bolts and stuff go...people have even put rx-7 lsd's in the r200v IIRC
I would be stoked if these was a drop-in affair.
gregfarz78
Car: 04 Honda S2000
turbo2nr wrote:i know what the gear ratios are, thats why i want the z final gear.
Just curious why do you want the Z final gear? Even the Z guys don't like it and swap them out for 3.9
turbo2nr
i like long gears, esp for the hi way.plus i have a big turbo so id like to make use of it, i hate only being able to do 110 in 4th..
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
rcabrita wrote:For people wanting to use V160 6 speed trans from the Supra for their 2JZ swaps, the 350Z's 3.3 final drive will be curcial.
Why not just take the ring gear out of the 350Z rear and plant it into your current R200 or R230? I have a R230 Ring gear from a TT Z32 in my R200
RCA
Because no one has tried it.Maybe the Z ring gear/diff uses more ring gear bolts then the 240 gear/diff.
Its not like these questions have been answered and using the Z pumpkin etc is the only way...But so far no one has tried to do that so I ASSUME that this would be the easier way
That plus IDK too many people who want to mess with hybrid pumpkins...Z pinon and ring gear in a 240sx R200...
Any thoughts or theories?
turbo2nr
i heard that all the r200 pinon /ring gears are the same its the output shafts and half shafts and pumpkins that differ.
but ill see if i can get a 350z vlsd cheap and compare it to my open diff ring and pinion.
weekend project if i can get this diff for under $50 bux
RCA
turbo2nr wrote:but ill see if i can get a 350z vlsd cheap and compare it to my open diff ring and pinion.
That would be awesome if you swaped the entire guts of a Z33's pumpkin into a S13/14's
That would be a nice little write-up
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
rcabrita wrote:Because no one has tried it.Maybe the Z ring gear/diff uses more ring gear bolts then the 240 gear/diff.
No heart man, just gotta give it a whirl. I think it will fit no issue but well have to find a guinea pig
gregfarz78
Car: 04 Honda S2000
turbo2nr wrote:i like long gears, esp for the hi way.plus i have a big turbo so id like to make use of it, i hate only being able to do 110 in 4th..
you would really hate driving my spec v then lol
spooled240
Car: kouki s14
yeah I'm ka-t as well with a t3/t4 and it's not hard to top out at 140+ mph in 5th with the stock 4.08 gears...I would like to tach about 2500-3000rpms at 80 on the freeway, that would be nice instead of the 3500 I'm taching at 80 now
turbo2nr
yea 4.08 suck for ka-t
the 3.9 from the j30 may suit you spooled b/c i know you like the 1/4 mile racing, so you wont loss to much down low and still lower your rpms when crusing, it really does suck crusing at 80 doing 3500rpms...
lrb_2000
Car: '91 Nissan KA-T hatch
Why does cruising at 3500rpms suck? I have a stock open diff welded and I can do 120 before redline in 4th.. and 150mph @ 6000rpms in 5th..
I got 30mpg on the highway doing 75 for 5 hours.. I have a fully built ka-t with a gt35... I guess it's the tune.
turbo2nr
crusing at 3500 is loud and ****ty bad on gas milage.
that odd i never seen more then ~110 in 4th, and my speedo only goes to 120, so i can only assume i got past 140 b/c that was the speed of the other car was going and i was ahead.
longer gears will be in my benfit for my driving style.
