350z Dies after excessive speed
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
driftersilvia240sx
Car: 350z (business car)
240sx (rb25)
civic eg (winter beater)
I fear my oil pump is on its way out 03 350z with 110,000....
after car is warmed up oil pressure does seems low 10-12psi on stock gauge. Blip the throttle oil pressure rises which is great. i do run royal purple 5w30. Anyways i like to speed and ill get on it, reach 130 or so coast in neutral and the Z dies...For a quick second oil light pops on and dies...So i fear oil pump, possibly bearings...Or could a faulty oil pressure switch be causing this...??? :frown: Love the car and the VQ. Will build if need be
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
What's the spec on the pump? At idle, the Z32 is supposed to only have more than 15.
Actually, just checked your FSM, spec is 14 psi. The stock gauge also isn't a very accurate indicator. I'd bet you're fine. If you're still worried, get an external tester and hook it up.
Where are you doing 130? My solution would be don't go 130 on public roads.
Mechanically what's wrong with it though, what kind of intake do you have? A lot of cone filters can cause turbulence that'll mess with the MAF and make the engine die.
Has it done this more than once? If not, I wouldn't be too bent out of shape about it.
Ace2cool
Also, tech forum for tech questions.
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
driftersilvia240sx wrote:...coast in neutral and the Z dies...For a quick second oil light pops on and dies.
Are you running a JWT pop charger, by chance?
driftersilvia240sx
240sx (rb25)
:gapteeth: Hey guys I didn't even think of the air filter being bad ...I have a aps intake and a fujita pipe and took a look at the filter shes quite dirty ... I don't have the car insured yet due to there still salt on the roads here in Michigan. But hey thanks guys ill keep you all updated. As far as me speedin, were all guilty of it don't kid yourself
Return to “350z / 370z Technical”
