[QUOTE=pooch1]Thanks,I just got the Canadian Tire drl module and wired the parking -running lights,it passed federal inspection and everything working ok.Cost is 25.00 from ct.It involves pulling the right wheel,removing the inner fender liner and locating the green wirefrom parking light bulb,confirmed it was power wire with 12 volt tester,tapped into it and connected it to yellow wire from module.The only other you need to connect is red from module to battery positive and black wire from module to the nearest good ground.The green wire from module goes to any ignition pack head.I cable tied it to #1 head and tested it.Lights come on 4 seconds after engine fires and delays 10 seconds on off.You stay away completely from Zenons so its actually less wear and tear than the factory setup.Everthing else works as per factory including all the regular settings.Located the module on right front strut tower beside main wiring harness.I will take some photos of installation and try to post.Ive done the same drl module on a Pt cruiser with the same good result.Email me at
[email protected] and I will forward photos when I get a non rainy day for pics. [/[IMG][/IMG][IMG][/IMG][IMG][/IMG]QUOTE]I have had a ton of emails on this so,Ill try to get pics soon,just been busy since I got back.To clarify again,the Hamsar module from Canadian Tire is used.The only wires you need are the red fused wire to your battery.The black ground wire to a good ground,found one on right strut tower.The yellow wire that is run to the green wire running from back of right headlight assembly.And the green wire from module that is strapped to the head of any ignition pack head.Make sure you strap it to the head(high voltage) and not to the lead wire(low voltage) or it will not sense the ignition being on and will not switch the lights on.I shrink tubed all the exposed connections before I finished.Please realize the right wheel assembly is removed to gain access to the right inner fender liner,the liner is removed which allows access to the back of the light wiring.Ive done this to 3 cars so far and they all work great.Email me at
[email protected] and I will send you the pics,took them today. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
Modified by pooch1 at 9:39 AM 4/26/2008
