350z caliper upgrade needs new knuckles?
420sxWETDREAMS
Car: 1991 240sx Hatchback
I was doing the big brake upgrade and notice the bolts that go on the caliper from the 350z dont fit the knuckle that is in the 240sx. Anyone?
Razi
Car: Moo
Are you trying to fit the 350z Brembos on your car?
I think the fronts bolt up, but for the rear you might need to get a custom brackets made to adapt them to your knuckles.
420sxWETDREAMS
Razi wrote:Are you trying to fit the 350z Brembos on your car?
I'm actually putting the same wheels you have and I am putting the stock 350z calipers on the stock knuckles. The original bolts go through the knuckle fine, but dont fit the bigger bolt needed to go on the caliper. Is it safe to but the original bolt with washers on both sides and a nut to secure it? My DD sentra just died and I need the 40 to dail drive now.
Razi
Car: Moo
I think people drill out the knuckle to accept the larger 350z caliper bolt, but I haven't researched it in a while.
420sxWETDREAMS
I thought about that, and I have done quite a bit of research and cant believe I haven't seen or heard of this issue or seen a write up of some sort. Considering this is done almost every time some one upgrades and nothing?!
TheRealNap0le0n
Car: 1998 q45
should be fairly bolt on even for the brembos... IIRC the 350z brakes are a bolt on upgrade for 300zx soooo if the z32 brakes bolt on to ours cars then the z33 brakes have to as well
costa_rican13
Car: 1993 s13 coupe
i may want to do this if I plan on upgrading from my q45's. :)
