350z brakes on s14 240sx se question?
s14touge
Car: 1995 240sx s14
My buddy just upgraded the brakes on his g35 and is giving me the calipers and pads and rotors for free. I want to know will they work on my car. I know of the z32 upgrade but can i use brakes froma z33?
TerminalVelocity
Car: 1996 240sx
The front brembo brakes from a z33 will work if you switch to bigger lugs on the hub or something like that. I would assume the standard brakes would work with the same modifications. No go on the rears though.
s14touge
Car: 1995 240sx s14
oh ok. i just want front brakes anyway.
TerminalVelocity
Car: 1996 240sx
post up some picks when you get them on.
Blown240sx
Car: 1996 240sx
What? No The Z33 Brembo Brakes require a bracket to space them up and out because the Rotor Size is much larger.
TerminalVelocity
Car: 1996 240sx
Going off of this thread you just need the z32 lines and the enlarged holes.
where did you hear you needed the brackets?
s14touge
Car: 1995 240sx s14
ok well i will pick them up on monday and test fit them.
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
the z33 brembo brakes will work you just have to drill and tap the factory caliper holes to a bigger size so they will bolt up. now the bracket your talking about is for the use of the 350z track brembo rotors with the z32 calipers.
Blown240sx
Car: 1996 240sx
Ahh the makes since then. Although I cant figure out why youd pay $1800 for rotor and calipers that arnt much better than a $360 Brembo rotor/Z32 30mm setup.
lookleft
Car: ORIGIN S14 (SR20DET, brembo, BRIDE, SSR etc.)
I bought a Brembo Big Brake Kit from a G35 owner and it fit on my S14 using the same bracket as the Z32. Im sure your setup will work.
Lucky736
Any pics?
240lookis
Car: 1990 240sx hatch
you should post up some pics man.im about to put front z33 brakes on my s13 and i want to know if this works.
if lookleft is right, then all that we need are those z32 brackets.
gotbeef4brains
Car: 1993 Nissan 240SX SR20DET
i've tried this and to put the z33 brakes on a s13 you need big rims like 18's because i mounted my 17's on it and i didn't clear the calipers but i put the z32 brakes on my car front and rear and its simple, the e-brake is simple to make it work and with the z32 brake master cylinder and brake booster it gives more than enough braking power
