350z brake setup on S13
SacaCaca
People has anyone every tried to put 350z hubs on an S13????????????????
I really just want to know if they fit. because **** if i can get 350z hubs with rotors calipers and all........
thats sexiness no dout......my be different rims haha
J.E.I.
Car: 95 BMW 325I
I have heard of people doing it, but I have yet to see it done. I would be interested in seeing the track brembo's on a s13. I have the R33 calipers on mine and would like to upgrade to the brembo set-up.
Bump for more info!
SacaCaca
ye
J.E.I. wrote:I have heard of people doing it, but I have yet to see it done. I would be interested in seeing the track brembo's on a s13. I have the R33 calipers on mine and would like to upgrade to the brembo set-up.
Bump for more info!
yes .BUMP For more INFO or experience with 350z complete brake set up on S13
need4gforce
Car: 180sx
I know SPL had made an adapter to kick out 300z calipers to use the 350z rotors.. this was a front setup.. I dont see it on thier web page anymore though..... CONFUSED
Rex
Car: None
need4gforce wrote:I know SPL had made an adapter to kick out 300z calipers to use the 350z rotors.. this was a front setup.. I dont see it on thier web page anymore though..... CONFUSED
I had these parts to be installed on an S13 vert I had for a few months, then sold. Maybe, Repo Man can weigh in, as I "think" he might of installed all these parts.
MagikDragon
Car: 1991 240SX, 1992 240SX, 1986 MB 190E 2.3-16
the hubs I don't believe will fit. From what I understand 350z rotors and brembos will fit, but you need to drill out you caliper mounting holes to accommodate the larger bolts.
you can also get spec v brembos that are a bolt on affair.
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
I have Z33 track rotors on mine with Z32 calipers. The calipers do not sweep the entire contact area on the rotor, however you still get the greater mechanical advantage with the larger diameter rotor. Plus, they're pretty damn hard to heat up to the point that they fade.
I do have to use the now-discontinued SPL brackets to relocate the calipers, but they are simple and a bolt-on type deal.
Bottom line is that the car stops pretty damn well.
Repo Man wrote:I have Z33 track rotors on mine with Z32 calipers. The calipers do not sweep the entire contact area on the rotor, however you still get the greater mechanical advantage with the larger diameter rotor. Plus, they're pretty damn hard to heat up to the point that they fade.
I have the identical setup on Project Vert... G35 Brembos (slotted) with Z32 30mm calipers and Ferodo 2500 DS pads - Hellacious stopping pawer, especially with those fatass sticky front tires.
