The pedal would vibrate when coming to a stop. The vibration and pulse would come at around 15 mph until the car stops. The vibration is not present at high speeds. However, the pedal wouldn't vibrate when the brakes are cold so for the first mile or so the brakes make no vibration at all. I also checked if the steering wheel moves when I brake at high speed and at low speed when coming to a stop. The steering wheel doesn't move at all nor does it vibrate. I also didn't put a lot of grease on the pad.. could that cause it?
What do you all think might be causing this?
I also plan on bleeding the brakes and applying grease later but I doubt that will solve it...
Thanks, Any suggestions will help.
