350z BBK fitment
sroks5
Besides the rotor, calipers and brake lines, what else is needed to make a BBK from a 350z fit on a M35 rwd?
thanks for your help
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
another factor to consider is the type of wheels you're running....if you're riding on the stock sport wheels, then you'll probably need spacers...at least 20mm for the fronts...
check your offsets/sizing of your wheels if you're running after market set up...
there are some threads on here that talked about what other's have come across...
Partysan7
Car: 2008 M35
Are you asking about a Brembo bbk or the Akebono bbk ?
I know that 350z's and g35's need a conversion bracket to fit akebono bbk and akebono is a bolt on on the M. So perhaps the M would need brackets for brembo ?! Also a dot4 brakefluid is required and prefferably SS lines (optional) and some quality pads. As far as wheel clearance there are templates that you print out trace on hard cardboard and cut to see wether they clear or not. If not you can measure to know what size spacers to use
