350Z APS Twin Turbo
Nissan 350z / Nissan 370z general community discussion forum
fahadco80
Hi guyz,
I have a 2006 350Z and I would like to know what parts do I need to change so my engine can handle the APS TT? (like pistons, rods,....??)
Tommy K
Car: 2007 350Z
From what i read on the APS site is that u really dont need to change out anything. It all comes in a kit but it depends on which 1 u want. If u go 4 the extrem intercooled system u get a new fuel rail system and some easier stuff like that. It really depends on how much boost u want and what ur usin ur Z for. http://www.airpoweredsystems.com and check it out. Hope it helps
tooskerdo
Car: 05 350z track. ultra yellow, kit, blower, exhuast
Why do it twice , or after it breaks. APS is a good kit. It also packs a wallup to your engine when it kicks in. I would go ahead and strengthen it up a little. ( We all know it's eventually going to get hammered) The power eventually get's used to, the your going to want to boost it more. Spend another $2000 and replace some internal (rods for starters) and have fun w/ it and not have to woory weather your going to blow your engine! Good luck!
NSRsheets
Car: 2009 Nismo 370Z #85,1993 Nissan 240sx RB25DET coupe, 2013 focus
The kit should come with everything you need to run on the specified specs. If your running the extreme kit it would be a good idea to do some internals.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
if you stay within the setting for the kit as packaged you'll be fine, if you want to turn the boost up, pistons, rods, and headstuds will be the first step up, just depends on how crazy you want to go, there are strokers putting over 1000 whp! not what you call a stock bottom end
fahadco80
what if i would like to make my engine +750whp? what exactuly do i have to add or change with thw APS TT? note that I want it as a daily use car, plz help me with that..
thanks
Return to “350z / 370z Discussion”
