Actually this piece has more ground clearance than the stock piece does.Anthonysflying wrote:FYI the stock splash guards protect the engine bay from debris and improve aerodynamics under the car. Not sure if anybody else has more info on this but i believe it also helps with cooling by keeping air traveling inside the bay, around the engine before it can escape at the back of the block.
Those look great too! I'm curious about the lower offset you have there. The stock piece is pretty much flat. Is there a chance at high speeds that could lift the front of the car up a bit?
Actually, removing the underbody shrouding results in higher under-hood temps.Retired Chief wrote: Does it restrict air flow into the engine compartment, increasing the temps on pretty much everything in the engine compartment?
Modified by Retired Chief at 12:01 PM 10/6/2009
350Z Pans are done and ready for sale. I will get back with Greg shortly so I can post them for-sale here.SemperFiV12 wrote:Let us know about the 350s as well
Of course. Coupe pans are done 02-06ishEarly Sedan, 05 is being test fitted tomorrow. 07> sedan looks like it may use the 370 design I am working on which is almost done.audtatious wrote:Any G love? Hell, I could drive up there for install
Yes, they are the same.SemperFiV12 wrote:same fitment for 07-08 HR Z?
LMK about the '07 versions when they are ready and I'll look into it.Spddracer wrote:Of course. Coupe pans are done 02-06ishEarly Sedan, 05 is being test fitted tomorrow. 07> sedan looks like it may use the 370 design I am working on which is almost done.
zer...ieldsridered929rr wrote:Have a price yet for the 350?
Zero260 wrote:Will this work with the APS high capacity oil pan?. I want one but I don't want to be the first to find out it doesn't
I don't remember, I get the car on friday. I'll check then.Spddracer wrote:
Do you know if the oil pan sits lower than the cross member itself?
Zero260 wrote:I don't remember, I get the car on friday. I'll check then.
