You know the difference between the gear ratios right? And you know that more spread out ratios are better for a turbocharged car right? And you know the 6th gear of the 350Z/G35 transmission is shorter then the Z32 5th gear right?95NA300ZX wrote:Does anyone know if a 350Z 6spd transmission will fit on a 300zx twin turbo? I'm considering a manual trans swap for my Z because its an auto and I'm going crazy not being able tho drive a stick...I miss it so much. But anyways I was just curious to know because I'd rather have a 6spd instead of a 5 spd.
Not worth it. The 6spd is also weaker then the 5sp FYI.
