If you were wondering, the trans, crossmember, and shifter location has to be modified. Custom driveshaft will be needed as well.HavenAZ from AZ240sx wrote:
WHY:
I started developing this trans adapter because the market for transmission's for 240's isn't that great when you start pushing bigger power. I went through 3 transmission's in three events and i decided a beefier trans was in order. KA and SR trans aren't that strong. This includes aftermarket transmissions as well. The gears are still small and are likely to break. They also cost astronomical amounts of money. The Z32 trans is much stronger but it doesn't shift that well. So I set out to make the Z33 trans work with an SR. The advantages to using z33 transmissions are plentiful, strong construction, smooth shifting, much newer than z32 transmissions, and closer gearing (so you have what is essentially a 2.5 gear for skid pad and main track) for better power band range.
HOW:
What I did was build a plate that bolts to the motor and then the trans bolts up to the plate just as if you were attaching it to the motor. The plate includes flush mount hardware so that it mounts evenly to the transmission. The trans then bolts up to that plate with a new set of hardware that is also included. The trans bell housing has to be milled down 1/2" as the adapter plate takes up that much space, so by milling down the transmission no extra length/spacing is taken up. This makes mounting/shifter placement much easier.
HOW Much:
Just the plate and hardware is $500
^My edit should say it all dude.AZ89two4Tsx wrote:^ The picture should say it all dude.
I'll be honest, I don't know a whole lot about gearing and whatnot. I just thought it would be dope to have a 6spd.Razi wrote:Holy smokes that is huge!
If I ever got one, I'd need to pair it up to a longer final gear ratio.
1st gear is already annoyingly short on my mild KA-T setup
I'm not sure but your RPMs will have to be higher for the same speeds.simmode1 wrote:I'll be honest, I don't know a whole lot about gearing and whatnot. I just thought it would be dope to have a 6spd.Razi wrote:Holy smokes that is huge!
1st gear is already annoyingly short on my mild KA-T setupHell, that was half of the reason I wanted a VQ30DET: So I could put the 350z transmission on it. Now what's the point really? Just put the 6spd on a prepped KA...
But I know there are gonna be other guys who are gonna need to be similarly educated, like myself, so Razi:
-Based on that gearing you posted earlier, what RPM do you think you be highway cruising speed with this transmission?
-And I'd like to discuss the merits, possible applications and best uses for this pairing. Already sounds like the N/A KA would benefit, but by how much? What about low powered KA-T's and SR's? And VH powered cars?
Also, Razi... could you link those knuckles? They seem certified dope. Maybe we should make a thread cataloging and discussing all the big innovtive products for the S-Chassis...
So, for example: If your stock 240 does 70mph in 5th gear at 3000rpm, with a Z33 trans you'd hit 70mph in 5th gear at like 3400 or something like that?Razi wrote: I'm not sure but your RPMs will have to be higher for the same speeds.
If you look at the ratio numbers, just read it like "The engine has to spin this much to spin the gear once."
I did some searching and found that Pre-HR 350Z's cruise in 6th at 70mph around 2600rpm and 3000pm has them at 82mph. So if we can use their ring and pinion set, we should be good to go, right?Razi wrote:No you won't be driving at 2k rpm at 70mph.
The 350z's 6th gear is shorter than the KA transmission's 5th.
So if you're cruising at 3k rpm for 80mph on your KA transmission's 5th gear, you'll be cruising at like 3400 in the 350z's 6th gear.
If you get a taller ring and pinion set for your diff though, you can probably bring it back down to 3k rpm or w/e, I'm not gonna do the math. :P
maybe thats what you want? First result in google for z33 diff into s13I wanted the 3.538 gear ratio that is found in the stock 350z diff. I also wanted a Helical diff. Here is how I achieved the goal.
I started with the pumpkin out of a 1996 Infiniti Q45. If you'd rather have the 3.7 ratio then start with the 97-01 Q45 which comes with the 3.7
Next step was to buy an S15 helical diff off Ebay. Be sure you get the output shafts with it. You will need them and it's usually cheaper that way.
Since the Q45 diff comes with the same 3.538 ring & pinion as the 350Z I didn't have to mess with the pinion gear at all which made the helical install very easy. Simply remove the output shafts (I used a rubber hammer) unbolt the old diff, remove the ring gear from it and bolt it onto the helical diff with the ring gear bolts from the Q45. (Use thread locker).
Bolt the helical assemby into the pumpkin being careful to put all the shims back in the same way they came out. Check the back lash to make sure it's within spec. With mine I had just a tiny bit too much slop (backlash). I made a new shim out of a beer can and put it in on the left side to get the ring gear just a few thousands closer to the pinion. That did it and it turned out perfect. Tap in the output shafts, fill with oil and put it in the car
Side benefit is that the Q45 diff comes with a speed sensor that can be useful to make your speedo work because the VQ trans doesnt have a speedo sensor like the stock trans did.
When doing an engine and trans swap you will need a new driveshaft. I would recomend Doing the rear end swap before making the driveshaft as the Q45 diff is a long nose diff which is about a half inch longer than the stock R200 diff and it uses a larger input flange.
This is a much easier swap than fabricating a 350Z into a 240sx and you end up with a helical diff instead of a Viscous diff with the same gear ratio. Hope this helps someone. John
You're gonna want the speed sensor that the Q45 diff gives you. Otherwise you'll be running without one. No idea what the wiring for that is gonna be like. The complexities of this idea are now starting to hit me. Still want though.asoomal wrote:Can't we just stick in any R200 ring and pinion gear sets in the stock diff?
Probably.simmode1 wrote:I did some searching and found that Pre-HR 350Z's cruise in 6th at 70mph around 2600rpm and 3000pm has them at 82mph. So if we can use their ring and pinion set, we should be good to go, right?Razi wrote:No you won't be driving at 2k rpm at 70mph.
The 6spd manual has a 3.538 final drive ratio.
The 5spd automatic has a 3.357 final drive ratio.
So what all involved with using a 350Z ring and pinion set? Do we need to grab their whole diff?
Clarify, plz.OutToWinPAHC wrote:The final drive for a z33 6 speed is suckage.
