codyace »
https://forums.nicoclub.com/codyace-u28194.html
Wed Jan 25, 2006 2:20 am
IF thats ONLY what you want on a stock bottom end, here is a BARE BONES setup to achieve that safely
MSD 50lbs / Nismo 550cc InjectorJWT or Enthalpy ECUJWT S3 CamsGreddy RSPL I/C Kit3" ExhaustWalbro PumpBoost Controller (Either EBC or MBC)Cobra MAF/Z32 MAFUR Underdrive Pulley / SilkRoad Water Pump Pulley (for cavatation issues)Greddy Turbine Outlet
Now for turbocharger, you have 5 good options for your goal
GTiR T-28S15 GT28rGT28RSFP Big T28GT2871R .64 (although this is a turbo better suited for 350-390 whp)
(If I had to choose a turbo for 325 whp, I wouldn't think twice about getting GT28RS)
With the above mods and we'll say 16 psi, you should easily be over 300whp with those turbos. Push them all to 20 psi (except the GTiR and S15 GT28r) and you'll easily net at a minimum of 330 whp.
Those HP figures are conservative, as we all know no engines are equal, and there are more mods you could do to help achieve the power at lower PSI levels (such as intake manifolds, extrude honed oem manifold or aftermarket manifold, etc etc) but this is a bare bones answer.
