3500$CAD Setup..installed!
gepeto
Car: 1995 S14
- Turbo : T3/T4 .50 A/R Comp., .63 A/R Turbine, .57 Trim pics
- Oil lines : SS braided lines custom made by NPC Garage
- Manifold : Cast Iron manifold RevHard style pics
- Wastegate : 40 mm with 9 psi or lower depending on application
- B.O.V. : Turbo XS type
- Intercooler : Bar and plate type 12x24x3 or 4 depending on application pics
- I/C piping : painted mandrel bent steel custom made by NPC Garage
- Turbo downpipe : mandrel bent steel custom made by NPC Garage
- Injectors : sidefeed 550cc pics
- Fuel pump: Walbro HP 250lph pics
- Fuel Filter : 300zx stock unit
http://aliencow.com/3banger/ka24det.htm
What do you think about this setup?
lrb_2000
Car: '91 Nissan KA-T hatch
what are you using for engine management, clutch, gauges, fpr.. everything else looks good to me.
Modified by lrb_2000 at 10:38 PM 9/26/2005
gepeto
Car: 1995 S14
I have a ****ty centerforce clutch...
Engine management would be almasi tuning ECU (basically an OBD1 ecu reprogrammed with a switch for 4 different maps)
K240
Car: 1993 240sx
gepeto wrote:I have a ****ty centerforce clutch...
Is your clutch the Centerforce DUal friction? why is it $hitty?? I will probably be using one, and I want to know if there are any problems...?
gepeto
Car: 1995 S14
It's the lowest end centerforce...and I don't like the feeling plus it slipped on me once or twice...wtf !
